BTW,
@ROSELOA there’s really no need to call the phase setting USA System or European System at all because there isn’t a unified standard among manufacturers, or in other words, exceptions are commonly seen. Naming it USA System or European System only causes confusions.
It would be more effective to mark down which number (#1, #2, #3) belongs to which pin, instead of just using GND, HOT and COLD.
With the pin numbers, we users can easily find out and choose the correct phase setting (ON or OFF) in our XLR connections.
For example, the XLR pin #2 on my RA180 is HOT. In theory, all I need is to choose the matching phase setting with pin #2 that is HOT on my 150B. That would do.
But as shown in the image attached, there is NO indication for the pin numbers at all. That’s why I am confused, and so do many other users.
I’d appreciate it very much if you could help adding the pin numbers to the phase selection image in your next update (whether you want to keep the names of USA or European System or not), so that we won’t get confused any more.
Best
Tom
