I’m using Tidal playlists regularly.
When I jump straight into a playlist and start an title not at the start of playlist the RS 250 will not continue with the playlist. It will continue with recommended titles from the same artist.
When I want to start in the middle of a playlist I start the first titel and skip then multiple times until I reach the desired starting title.
Any hints on how to avoid this?
Best regards
KJM
Let me clear things up for you.
If you want to play all the songs in the playlist, press the yellow play button in the picture below.
For example, there are 22 songs in the playlist, and if you want to listen to the 3rd through 22nd songs, click the 3-dot button next to the 3rd song and click “Play from here”.
Playlist, Favorites, or any other song, if you play it, the song goes to the Queue. If the songs do not play in order, check if the functions marked in red in the picture below are white.
Thousand thanks.
Your explanation clarified my issue. I didn’t used the 3 dot menue to start the title within the playlist.
Best regards
KJM
