Everything is almost perfect with my RS130. I’m just missing Gapless for DSD.
Will Gapless for DSD files (DSF) be implemented?
Although you can listen to ISO images of SACDs, I can’t listen to my Otis Taylor Hey Joe disc in DSD256, for example, because these are downloadable master files that I can’t convert to ISO, so they can’t be Gapless. Well, that’s no big deal, but it would be a plus.
Regards
When using the Gapless function, it is not that DSD music cannot be played, but it is currently blocked by our software. When using the Gapless function, DSD sound sources can be played, but noise occurs when playing some DSD sound sources. We will identify and fix the issue as soon as possible.
