I have done some searching and found an answer regarding native dsd. If i understand correctly, neither device plays a roon stream dsd file natively. Instead it converts it to pcm and within the DoP container.
If you do the exact same thing with the matrix audio mini-i 3 pro, it plays the file natively within roon.
I only bring up the matix unit because it has the same dac as the 250, the ESS ES9038Q2M.
Is it safe to assume the reason for the conversion to PCM in the 250 is software related and not hardware or is it a difference in design? If software, it then could be fixed. If design, there is low probability of a fix and as such all potential buyers should understand this is how their unit will perform.
I am interested in purchasing a one of the Rose streamers but wont until i can get a better understanding of this issue. If its software and its on the radar to be addressed in the future that would be good enough.
I may have gotten it wrong but if one of the streamers (either 250 or 150) does process streaming via roon natively (and doesnt convert to PCM), please let me know. This information is not addressed in the manual and is not readily found in a deep search.
Thanks, in advance, for any info that would help clear up this issue as my purchase is awaiting answers.
Check out this thread
If its true that neither the 150b or 250 supports native usb streaming via roon, why does it say it does in the manuals?
Which is correct? The manual or the answers received in this forum?
Thank you for taking the time to post and help me out.
Much appreciated
Asking here also and again:
I see here a misunderstanding in using the Rose device as USB DAC or using an external USB DAC with it.
If you’re using the RS150 or RS250 as Roon endpoint, than DSD256 is the max (and not DSD512), because Rose uses with Roon always DoP.
If you connect than an external USB DAC, then this DAC must support DoP and also here you’ll limited normally (depends on the DAC) to DSD256.
