Does / can the RS150 support DSD upscaling? For example receiving a non-MQA stream and it apply DSD to it - like Roon currently is capable of, it seems to have a reasonably powerful CPU to potentially to do this.
Do you want to convert a non-MQA stream to DSD for save the file or digital output?
No, streaming. So a stream is received and it’s up-sampled on the fly to DSD128/256 etc. Roon does this, just wondering if your device will.
dsd to pcm already supports up to dsd128.
When converting pcm to dsd, max dsd128 is the max limit.
The dsd upsampling function is planned to be supported, and it will take some time( maybe 2month later ).
I have a dsd dac that I connect from rs150b via USB out. The rs150b recognized my dac as combo384 amanero but it does not upsample my local flac files to dsd.  I have configured the USB output to DOP,  I wonder where it could went wrong?
