Dual USB-A head cable connect to external DAC issues
After the newest Ver 4.0+ update, my RS150 cannot detect the external DAC upon the DAC select the USB input. Please advise. Thanks.
Can you take a photo of your USB cable?
Also, what’s the model name of your external DAC?
Hello there,
The USB cable info as follows:
https://www.tubulus.net/product/tubulus-argentus-usb-cable-dual-head/
Brand & model: Tubulus Argentus USB Cable V4 Dual Head
The external DAC is: Denafrips Terminator Plus
Link: https://www.denafrips.com/terminator-plus
Thanks.
  1. Are other devices connected to another USB-A head?
  2. If it is connected, disconnect it. When disconnected, does RS150 recognize your DAC?
  3. If you use a different USB cable, is RS150 connected to your DAC normally?
  1. Yes, a USB thumb drive.
  2. Yes, resolved.
  3. Single USB-A head is fine.
    Thanks.
