DVD / BlueRay Play
Hallo,
Nachdem es ja möglich ist eine CD abzuspielen, frage ich mich ob es vielleicht in naher Zukunft möglich sein könnte auch dvd oder vielleicht sogar BlueRay abzuspielen ( natürlich mit entsprechendem Laufwerk)? ?? Oder gibt es die Funktion schon und ich habe es noch nicht gefunden….
Gruß
André
Since it is possible to play a CD, I wonder if it might be possible to play DVD or maybe even BlueRay (with the appropriate drive) in the near future? ?? Or does the function already exist and I haven’t found it yet…
Greeting
André
@Bitstream66
Do you have a CD ROM or CD player? If you have it, connect it to your Rose device. If you look at the screen of your Rose device, you will see the PLAY CD app. You can play a CD by pressing the PLAY CD app.
안녕하세요. 답변 감사드립니다. 그러나 질문은 다른 것이었습니다. 어느 시점에 DVD나 Bluray를 재생할 수 있습니까?
@Bitstream66
Blu-ray/DVD cannot be played directly.
You can play it after ripping it on your PC.
네, 그건 알아요. 문제는 그것이 미래에 상상할 수 있는지, 아니면 이미 계획되어 있는지 여부입니다.
@Bitstream66
This part is not currently planned for addition.
