When I want to change the metadata of an album only the first line is editable.
It is not possible to modify the following lines: artist, disk name, etc.
The artist and track names can sometimes be different, so the system is currently set not to allow batch editing.
If you would like to change the Title, Artist, Genre, or Composer, please try the following steps:
RoseConnect app → Music → Album → Select the album you want to modify → Tap the three-dot menu next to the track you want to edit → Metadata → Edit
