Eject CD -> restart
System OS 5.9.09
Roseconnect 1.0.22.3 (Android)
If I try to eject a CD after it has finished playing and stopped, I get the confirmation pop-up, but if I confirm the CD starts to play from the beginning. If I try to eject it while it’s playing, I get the confirmation pop-up and when I confirm the CD ejects.
Thoughts?
@JerrySNB
Based on your description alone, this does appear to be an issue.
The issue has already been forwarded to our software team, and we will do our best to resolve it as quickly as possible.
I forgot to mention that I’m using an RS250. Also, the older app had the same problem.
@JerrySNB
Yes, our software team is currently investigating this issue.
We will get back to you with an update as soon as possible.
