I have all my music on an SSD within an RS130.
When I search through my library using the Rose app on an iPad Air, many albums (perhaps all - with thousands of albums I haven’t checked all) appear twice in the music library.
When I check the file information, in one album the tracks appear as gthey should, with the correct sample rate and bit depth. But in the other album the tracks show as having a size and sample rate of 0. Obviously, if I try to play these albums, I get no music.
I have exactly the same tracks on a NAS attached to the network, and if play those use via JRiver or Roon from a laptop using DNLA to the RS130, I don’t have this problem. And I know that the files aren’t doubled up
Any explanation for why this happening, and how to correct it?
