Can anyone help me how Equaliser on RS250 works? And when can I use it?
EQ function has been added to the current RS250.
RS250–>Audio Settings–>Equalizer
Set OFF to ON in the equalizer, and after setting the value you want, press SAVE in the upper right corner.
Thank you, all good with that. Does the equaliser work in all input/output settings? I tried with different options but with no luck, can you clarify? And also help me how to check if there is another problem?
EQ is applied when playing Rose Tube, Video, BT, Airplay, and CD.
For questions about how to check when other problems arise, you must first tell us what the problem is so that we can answer.
My RS250 only works with equaliser when output is set to RCA/analogue output.
ROSEHAN,
Pls clarify, does this mean that when I play music via Tidal or Qobuz, the EQ is not applied?
ROSEHAN,
I would appreciate a detailed manual for Custom settings of the EQ.
I cannot make it work properly.
Many thanks in advance!
/Torkel
Good luck with that Torkel!
Hi-Fi Rose’s EQ function does not apply to Tidal or Qobuz individually.
Below is a detailed description of the EQ function.
Thanks for the quick reply and the Manual!
Your answer can be interpreted in several ways.
Does this mean that the EQ function is applied to all music streaming when set to ON?
BR,
/Torkel
