Equaliser/Tone Controls RS150
Hi when will you be adding an equaliser or tone controls function to the RS150. It would be fantastic if you could incorporate the same equaliser like you have on the RS250 (or better), it would add to the flexibility and functionality generally and in particularly with line input or other sources.
My phono preamp is connected to the line input and the sound can be bright at times it would be good to be able to use an equaliser or tone controls to improve the sound. It is odd to me that the flagship model RS150 has less functionality than the less expensive models like the RS250.
We are going over about adding equalizer for RS150 and RS250.
We will notify you when it is confirmed.
Please take care when adding the equalizer in making sure it doesn’t degrade the sound quality due to the extra processing needed. It would be good to also have a equalizer bypass facility.
