How to erase a single track from a Tidal My Playlist?
RoseConnect → Tidal → My Music → My Playlist → List1 ->3 point menu on the right → delete
Please let me know if it doesn’t work.
Thank you,
Hello @ROSELOA ,
I can delete the whole playlist this way. But going into the playlist to delete one track, there is no delete function in the 3 point menu.
Did you touch the 3 point menu next to playlist or a song?
3 point menu next to playlist will delete the playlist and 3 point menu next to a song will delete only one song.
However, please try it in ROSE device, as RoseConnectPremium has error with it.
@ROSELOA You’re right. Deleting a single file works on the device but not in RoseConnect. Hope this will be fixed. Thanks.
Not only ROSE can’t do that…
I use TIDAL app to editing playlist.
