Ethernet cables
Having just bought my first streamer, the Rose RS151, I have been reading rave reviews of the AudioQuest Vodka RJ/E ethernet cable. I wonder if any users have a comment on the difference a good ethernet cable can make to a system. Any recommendations welcomed.
Hello, I’m currently using Audioquest Cinnamon. I also had the opportunity to test Audioquest Vodka, but I didn’t find any improvement over Cinnamon. However, there is a real improvement, at least for me, with LAN iPurifier Pro - Ethernet Filter with Optical Isolation.
Save yourself some money.
As long as a cable is made to spec and has quality parts… its going to sound the same.
Just get a decent CAT 8 cable and you’re good to go.
Thanks MEK. I shall investigate the filter option.
Your comment is noted Smegel. I’ll get a couple of decent CAT 8 cables.
If you want to have the best compromise, then take a CAT6e unshielded (TPU) cable for a few bugs.
Cat 8 cables are a good way to get some ground loops, and are stiff and expensive. For a streamer, which does not need (and does not support anything faster anyway) even a 1Gb speed Rose has, a well-made Cat6e cable is all that is needed.
Boris… that’s got to be some of the dumbest things said.
So wrong.
Just to follow up… Ignore Boris because he has no clue.
The difference between a CAT 8 wire and a CAT 6 wire is as follows
The CAT 8 has slighly larger gauge of wire (One size larger in terms of AWG)
Better components. Better shielding.
They are built to handle up to 40gb/s and you can use them anywhere you use a lower grade CAT cable.
So please Boris site your evidence that they can cause ground loops…
Should also add.
The CAT 8 cable is probably a few dollars more than the CAT 6 cable… so yeah… there’s that.
I just did a quick google a 15’ CAT 8 cable from Walmart is $10.00
So prices are all over the map but usually around $15.00.
YMMV
Edit… actually you may find CAT 8 patch cables actually cheaper.
Thanks Smegel. I am over-egging the cake perhaps, but I have ordered 2 lengths of Furutech LAN-8 NCF Ethernet cable - 1.2m for my Synology NAS to my router, 2.5m for my router to my RS151.
Hopefully that compromise will cover me until CAT9/10 appears.
Incidentally, I am going to post another question on the site regarding transferring files from NAS to the internal SSD on my RS151. Thanks again meantime.
Having the Audioquest Vodka Ethernet in my chain i can very much recommend that one.
As an alternative the FuruTech NCF LAN 8 is close to the Vodka.
That is good to hear. Thanks Christian.
There will be no CAT 9 or anything past CAT 8.
CAT 8 is hitting the limits of what you can do w copper.
If you need speeds faster than 40gb/s, you end up going w optical.
Seriously you have to remember that digital is different than analog.
Its your money… but buying good quality commercial grade CAT 8 patch cables is all you need. Just buy them from a reputable dealer/store. For me… in the US… MicroCenter is my go to store since I’ve been shopping w them for over 40yrs and I live within a mile of one. NewEgg is another online store, and then you get into the specialty networking stores. YMMV depending on where you live.
Thanks for the further education lesson, maestro. Appreciated.
I live in Scotland actually. Point taken on money-saving but the Furutech cables are en route to me (they are less than half the price of the Audioquest Vodka cables I was considering).
Further, I have ordered from Stack Audio one of their SmoothLAN Network Filters, which is not quite as expensive as the option MEK had suggested earlier, but still highly rated by serious commentators.
Mate, spent 9 months in Stirling.
When my wife came over for holiday, had to visit the Kelpies in Falkirk.
Spent some time visiting my nephew in Edinburgh while he was at Uni during the same time.
There’s a lot of overpriced kit out there and a lot of claims that make you want to scratch your head.
Its like those ā€˜audiophile’ switches. Sure they use good components… but they are made in small batches so you’re paying a premium… yet if you buy a commercial grade switch rated for higher throughput you’re getting the same performance for less.
But to each their own… the biggest bang for your buck will be room treatment. Then speakers.
Yeah, so sorry that facts always trigger you!
Which is nice if you are actually trying to push 40Gb over short distances. What does it do for streamers, which have at best 1Gb network adapters? Absolutely nothing.
Which is OK if you are trying to build a mediocre backbone, but quite useless for streamers. And if you are making a backbone, just run 100Gb fiber anyway.
Audioquest are outright crooks and sell things that simply do not exist. Like a directional ethernet cable.
I don’t think ā€œwill say anything for moneyā€ describes a serious commentator. There is no such thing as a ā€œnetwork filterā€ that would do anything useful.
OK, I hear/read what you say but I have today installed a pair of Furutech CAT 8 cables - one from my NAS to my router and the other from the router into a Stack Audio SmoothLAN network filter which I plugged into my RS151. I have never enjoyed listening to my NAS so much. 2D turns into 3D and I am hearing backing vocals and chords I never heard before. Everything seems so clear now.
I am so enjoying my snake oil. Why don’t you try before shouting nonsense from the rooftops?
:+1:t2: :+1:t2: :+1:t2:
I think if you can’t hear the difference between a chain where you are managing for EMF/RFI (with clean power and good cables), particularly where a single box is moving from the digital domain to the analog domain, then your system isn’t revealing enough and you have a bigger problem to solve for than EMF/RFI.
The digital is digital thinking will limit your ability to enjoy this hobby. In fact, why are you all buying high-end streamers if digital is digital?
Typical bullshit from people who can’t accept that they had spent tons of money for absolutely nothing.
People with IQ above 50 buy them for features, looks, and convenience. The rest do believe that their special cables and fuses lift veils and darken blacks. Because they hve IQ below 50.
