I have a turn table phono output going into a phono stage preamp. Should I connect the output of my phone stage preamp into RA180 line in 1-3 with bypass-power amp mode off? Or would it be better to connect it to line in 3 with bypass-power amp mode on?
Does the phono stage preamp source need to run through the RA180 internal pre amp? I would t think so as it is a fixed line in, right?
