How do I reset RS201 with all Chinese language? I don’t understand. I want to reset go back to English. Please help. Thanks!
I will explain with pictures how to change the language on RS201 when it is set to Chinese.
Please select the red part shown in the picture below.
Hello Rosehan.
Thank you very much for your help. My RS201 ethernet not working, no light blinking. Where do I send the unit to repairs? Thanks.
Please check a few things.
- Does the connection not work the same way when you connect a different Ethernet cable?
- If you connect the Ethernet cable to a streamer or PC other than RS201, will the Internet connection work properly?
- Does the same symptom appear even if you factory reset your RS201?
RS201–>Settings–>System settings–>Factory reset - Even if you disconnect and reconnect the power cable connected to your Rose device and press the power button, do you not have light blinking and no response on the display?
If the same symptom appears even after trying the above, contact the distributor in the country where you purchased the Rose device and request repair.
hifirose.com/Distributors
