Fast Forward Option in Remote Control
Could you please add a fast forward option while playing the music in the remote control while press and hold next/previous buttons? It’s an important missing feature.
Regards,
Hello @jisharka
Those functions that you said is not supported with BT remote control.
We are aware that we need to add such a function, but there is no release date yet.
If you use RoseConnect, you can control functions more conveniently, so please use RoseConnect.
Hi, Thanks for your quick reply. As you can see the attached screenshot of Android TV VLC Player, we can select the “music slider” using remote UP/Down function. In HiFi Rose software, we cannot move section to the slider… (It moves around all other menus, but not moving in to the music slider). Once it is selected we can use left/right arrow keys for fast forward and reverse functions. I think this can be done through a software patch. Let us know your thoughts… RegardsScreenshot
