Favourites Managament (Qobuz)
First of all i would like to mention that all of the STreaming apps are doing it wrong (my oppinion) on how they organize Artist, Album and Title.
I believ this should be organized in the way like “planet earth”, City", “Adress”, “Name”, “Title”, which means i would like to have the Band in Bold and the subsequent Album small.
Now this might be something to deal with in Options?
Even more important, i woud appreciate if there was a chance to sort Albums chronologically, anti-chronologically and alphabetically.
Instead they seem to appear on a random order.
I am referring to the Apps (Mobile and Computer) → Quobuz → Home (aks “mein qobuz in german Version” → Search or Favourites.e.g.
Is this something that could be implemented or even is available and i didn’t find it yet?
Appreciate your feedback !
I should add that syncronmization does not work in the expected way. I see 44 Albuns under Rose Favourites, whereas i have probably several hudreds of Albums as Favourite in Qobuz…
  1. I’m sorry but we do not have plan to edit app design at the moment.
  2. The tracks, albums in Rose > Qobuz > My Qobuz > Favorites are listed in the order it was added. I’m not sure if they can be reordered as you’ve mentioned, but seems like good idea. I will check about it.
  3. Do you mean that you don’t see enough Albums here?
    Rose APP > Qobuz > My Qobuz > Favorites > Albums > View more > Scroll down the screen, but no more albums?
Thanks for your feedback.
In regards to
3. No, i mean that the synchronization does not work as i understood.
Meaning i do see all Favourites in the Qobuz branch of Rose App (Rose APP > Qobuz > My Qobuz > Favorites > Albums), but not in the Rose “Home” Branch.
Probably i di not understand the functionality correctly?
Kind regards
are you guys going to fix that problem ? i got 150 artist added to qobuz and its very hard to find them when the list is not alphabetized
