I have a Rose RS 130 which I connect to a number of DACs.
Each of these DACs has varying capabilities to accept Sample Rates or DSD vs. PCM. For example, to connect to my Sonos system I need to drop the max sample rate to 48kHz and to play DSD files use, DSD over PCM, instead of DSD Native.
I am sure, I am not the only one with multiple DACs connected to the same streamer.
How would this work:
USB: Max sample rate / DSD Native
Optical: 48kHz Max with DSD over PCM
