Feature wish: Analoge input sensitivity Level
Background: A Vinyl Preamplifier (set to max of 60dB gain) is connected to the RS250 analogue Input. RS 250 Output not high enough to drive power amp to maximum.
With higher amplification/sensitivity (as already implemented in the fixed mode out Pre-out), this would solve the issue. It´s also useful to equalize different Volume offsets from all sources.
Hello, I will pass it on to the developer so that they can refer to it when developing the next product.
Thanks !
IMO this can already be solved on the RS250 via Software.
You have already implemented it for the fixed level output.
The same values for selection for the variable output for max VOL and spreading the lower levels accordingly would solve it.
Thanks in advance for checking and perhaps one of the next sw-updates !
