Hi there,
Now that I’ve been using my Rose RS150b for a week, I decided to give some feedback of my thoughts. Also, this thread contains some feedback and suggestions for Rose.
Good stuff:
- Stunning audio quality. I’ve compared it with the built-in DAC in the Hegel H390. The audio that the RS150 provides is more clear, more vivid and the sound stage is open and wide.
- Great design. The screen is lovely with an overall good response.
- The hardware seems great built. E.g. the linear power supply and the ESS SABRE ES9038PRO DAC chip.
- Lots of input and output connections.
- The ability to use the RS150b as a preamp.
- The ability to display movies and music videos on an external screen (up to 4k / 60 hz).
- The unit is Roon Ready and it works great.
Not so good stuff (room for improvement):
- The Rose CONNECT app for iOS is lacking a lot, it could use some improvement. I’m using the unit with Tidal and I can’t see my Tidal playlists or songs, despite it’s available on the unit itself. Only the last played ones in the app.
- The Rose CONNECT app for IOS description in the Apple app store is in Korean (please see attached screenshot).
- The version history in the RD150b is in Korean (please see attached screenshot).
- The unit seems unstable sometimes. E.g. I could not use RoseTube two days ago. The app didn’t respond to user input (touch / search) however everything else was working (e.g. Tidal) on the unit. Yesterday it worked fine.
- There are typos and spelling errors, especially in settings. Examples: “Lastest version”. SystemInfo is in two words, same for SystemSetting. And “setting” is plural, e.g. “System settings”.
- The unit is loaded with Korean playlists and other things. How to delete that?
- The unit supports Spotify Connect and Apple AirPlay but not Tidal Connect. It’s a shame cause the audio quality of Tidal Connect is superior to the other mentioned audio transports.
Thank you Rose for a wonderful product. I’m looking forward to improvements. Today I’ve just downloaded the latest software upgrade for the unit. The suggestions / errors mentioned here doesn’t seem to be fixed however.
