¿ en que menu del 150B está la posibilidad de seleccionar un filtro u otro del DAC?
Gracias
Hello @nachocom
no sé español Lo explicaré con imágenes.
Por favor, haga clic en el área marcada en rojo
Seleccione la configuración deseada en el paso 1 y haga clic en Aplicar.
Thanks.
I found the filters.
Can you send me a graphics example of each filter Works with the sound response ?
Oh, perfect. Thak you.
One more question: to make balance?..to up the volume in each channel separated…is possible?
Thanks again
Hi. is it possible to have the same table (FIR) for RS250
Hello @anon94569189
The Fir Filter of RS 250 is almost the same as that of RS150B. Changed “Hybrid Fast Roll-Off” to “Corrected minimum phase Fast Roll-off”.
“Corrected minimum phase Fast Roll-off”: Low pre-ringing and the phase response varies at higher frequencies. There is more post ringing compared with linear phase and apodizing filters. Apodizing (SA20 default) – A compromise between phase, frequency response and ringing.
thanks for your description.
stefano
