My RD160 is on 1.20 as purchased. I am trying to follow the instructions and am asking for help from anyone who has successfully updated the RD160.
I have a USB C flash drive. Formatted in MS DOS FAT32 (as received). I Download the zip file from Support site and according to the instructions, the file should be installed as the .zip file. Put that drive in the SVC port and nothing happens. Unit is on since they don’t say anything about tuning off and on. If I unzip the file and try the same thing, I get nothing as well.Should this be installed as the zip file or the unzipped file? The file as downloaded is called 67e026857837d.zip - I’m on a Mac so I don’t know if that is the issue but I’m following the instructions.
Anyone? If the file name is different for someone on a PC, I’d be interested in getting the file exactly as it needs to be to install correctly.
I don’t know why this needs to be this complicated in 2025. In an ideal world, the RS130 which is connected to the internet could just push firmware updates to the RD160.
