A recent update turned off my analog output settings and I can’t remember which level to use. I am using the 150 pre out via XLR cables to the CD input on my McIntosh C2300 tube preamp, which is connected to a McIntosh MC 275 tube power amp. Any advice as to the best level to use as a fixed output?
If you’re using the RS130 with a McIntosh C2300 tube preamp via XLR and want to use it as a fixed output, we recommend setting the preout level to 2500mV or 3000mV. This provides a strong, clean signal without overloading the preamp input.
If you experience any distortion, you may lower the level slightly. Let us know if you need further
