Can the folder structure be improved by ROSE as it is not good at the moment. See the two pictures below how I had my music organised the last 10+ years and it worked with any streamer so far.
The way it works at the moment is no good as when I select Songbird it will play all 4 CD’s as I cannot select only one CD! This is URGENT as it is BS how it works at the moment!
If you use the ROSE folder structure you have to scroll for ages to get to the CD you want to listen to!!!
