Following an update to Rose radio BBC radio has disappeared
Hello
Today I have lost access to BBC radio. Rose radio said it had updated.
The same problem occured last time it was updated and you found BBC radio needed adding back to your server.
Thanks for help
I had the same issue.
I was able to reinstall my BBC radio stations by adding the URL from each station using the link from this website:
Make sure you open the original file and not the truncated version.
Then go to Rose Radio > My Rose Radio> Add My Channel and all should be fine.
Hope it works for you.
