Is there any way to have my Apple devices see the RS130 as an Airplay 1 device instead of an Airplay 2 device? When Both ends are Airplay 2, the iPhone or iPad will send 256kbps AAC. However, if one device is Airplay 1 then it will use ALAC instead. There are some downsides to Airplay 1 but I would rather have the functionality of the iOS app to play Apple Music on the RS 130. For example, the built-in AM app in Rose connect does not have access to my personal radio channel which I use all the time.
Thanks!
John
