Functions after RS 130 Factory Reset
I reset back to factory to prepare to sell my RS130.
I had a change of mind, however after signing in using my existing Rose One account information I cannot switch between Rose Radio and Qobuz on the App as I used to, it stays on what ever I started with and I cannot select the other, it feels like there is some confusion with my account.
Have I missed something?
@Smarty28
When you perform a factory reset, the apps installed on your RS130 are removed.
Therefore, if you want to use apps such as RoseTube , Qobuz , or RoseRadio , you will need to open the Rose Store on your RS130 and reinstall the apps you wish to use.
If this does not address the issue you are experiencing, please provide more details about your situation so that we can better assist you.
