My music is on a SSD drive connected to RS150. In the Rose Connect app under the Music>Classification>Genre… Selecting a song from here to play does not work. Is there a fix for this? Is there plans to make a search option within genres a thing?
Is your SSD fully scanned?
- RS150 > MUSIC > Setup > Media Library > Is something on progress?
- Your phone > RoseConnect APP > Settings > Media Library > Reimport database
Please check after the steps above.
Thank you,
That was the problem. After everything loaded I was able to play something from the genres tab. Thanks!
