GND on Rose 130
Has any one found the GND on the Rose 130 streamer useful? I recently added the Gutwire perfect grounding cable to my Holo May dac and found a very good improvement, so have now just bought the Ultimate cable from the same company that fits to a spare rca socket.
Does anyone make the use of such improvements and which way have you carried it out? ie grounding box etc…
@chrisjames
The GND terminal on the RS130 is designed to help reduce ground noise between connected devices.
Its effect can vary depending on your system and power environment.
Some users connect it to a grounding box or the GND terminal of another component (e.g., DAC or preamp) and experience a slight improvement in sound quality.
You may try connecting your Gutwire grounding cable to the RS130’s GND terminal to see if it benefits your setup.
Thanks ROSEHAN for your reply and extended information regarding connecting GND between devices. I will add the Gutwire grounding cable to the Rose 130 and listen to see if there is an immediate lift in SQ or if I notice more over a longer listening period, using the cheaper Gutwire grounding cable with the Holo Audio May dac I noticed an immediate improvement, just less digital glare and a darker background with less noise.
I know such improvement are system dependant and the results may vary from different devices.
Once I have a conclusion I will update on the results over the next week or so.
@chrisjames
We completely agree — grounding improvements can indeed be system-dependent, and the results may vary depending on the components, cabling, and overall setup.
We appreciate that you’re taking the time to test the Gutwire grounding cable with the RS130 and to evaluate any potential improvements in sound quality.
Please feel free to share your listening impressions once you’ve had more time to test.
We look forward to hearing about your experience and any differences you notice over a longer listening period.
Having added the Gutwire grounding cable I can confirm a worth while improvement, so far I have connected up the Holo May Dac and the Rose 130 streamer, also while doing it I connected 2 AfterDark PA1 optical modules to the grounding cable.
@chrisjames
I’m glad to hear that you’re noticing positive results.
If you have any additional questions in the future, please feel free to let us know.
