Goes into Cache mode
Recently, Everytime I use the hifiRose app on my iPad and go to Rosetube and play a videoclip either on Rosetube or in Youtube (under Rosetube) the video starts and in a few seconds stops, chache red indicator comes on and it takes a few seconds again before the video starts. Would never happen before. Very irritating. Have cleared the cache and tried. No use. I have a 2TB ssd installed. Has someone had the same issue? Rose connected to fibreoptic Ethernet with good speed. Please help
Thanks in advance
@Suhas420
If a network buffer underrun occurs, it will inevitably be disconnected, so you should check the router network. If you are using Wi-Fi, try switching to wired LAN, and if the problem persists, try resetting the router (not powering it off/on).
