Today got my RS130 and after a non issues installation I already can say bass is better than with RS150
Also there was a lot to read about the new screen but I can assure you it is really IPS and very sharp.
Next few days will listen a lot but first impression is very good
Pleased for you Bitspeed.
Bitspeed,
Congratulations on the RS130.
Those are a couple of sweet DACs. Which is your favorite? Why?
What connection are you using? USB? I2S?
Is streaming music from the Internet any different than your prior HiFi Rose?
StandardModel.
I did connect i2s with Audioquest hdmi Chocolat 0,6 mtr
First impression is very good, did not see any misspelled translations yet, the screen is really very, very good and the sound seems to be more detailed and dynamic but it’s hard to tell because the 150 is sold so no possibility to compare.
But I did play some songs I really know very good and there is a positive difference.
Hope there will be reviews soon in which they compare the two.
I did use the terminator II already with my 150, also with i2s so the sound difference is really inside the 130
Did not discover any bugs until now but only playing for 2 days now.
received mine today too, my first rose product. is there a way to change the display with only the remote?
mine sounds fantastic. app was a bit frustrating though. is there an app walk thru video anywhere?
also, how to make it play video to TV and sound thru stereo??
Got mine today! Frustrated that it isn’t roon ready as advertised, will not run on my setup with roon
i’m finding the app to be buggy. i’ll open it, press to play something and nothing happens. tried with several different albums and still wouldn’t work. had to exit the app and restart the player, then it would work.
