Does the RS250 / RS201E grounding terminal accept banana plug?
Yes, RS250/RS201E grounding port accept banana plug and there seems to be no problem in using it as a grounding wire.
Thank you. So even the new RS520 can take a 4mm banana plug in the ground terminal?
