Hi guys,
Can someone let me what’s the biggest size hard drive the RS150B can take?
Regards Matt
hi Matt
the max SSD_SATA 7mm thick that can take the Rose 150 is 4TB
Hi harry33,
Thanks for the reply mate what about the normal hard drive 3.5”?
Sorry not a SSD drive.
Regards Matt.
Matt,
the normal 3,5" won’t fit inside the RS150, u should find a SATA normal 2.5" 7mm thick drive. Yes could be standard HD(Not SSD) But according the user manual, the SSD type id recommanded.The problem is geometric, the drive should be able to fit in the spot reserved for.
Hi guys,
Thanks for helping but what about size? As a 4TB drive is not big enough for me.
Regards Matt.
The max size supported for internal drive is 4TB. External hard drive via USB connection, you can install 10TB drive
Hi harry,
Thanks for getting back to me ![]()
Ok via USB is only 10TB supported?
Regards Matt
Upto 10TB for HDD and 4TB for SSD is tested.
For reference, few ROSE users have reported that 8TB SSD works well in RS150, but no test done officially yet.
SSD used by the ROSE user:
