Would like to use tv audio with my two channel system. Using HDMI from Sony earc to RS151. The connection only works sporadically, what am I doing wrong?
We apologize for the delayed response.
Please help us confirm a few things:
- Is your RS151 connected via an HDMI cable from the eARC IN port on the RS151 to the eARC OUT port on your Sony 95L TV?
- In your RS151 input/output settings, is the input set to eARC IN?
- Please check whether PCM output is enabled in the settings of your Sony 95L TV.
