Hi @ROSEHAN,
I have a RS520, and need to make an adjustment on the volume on the hdmi arc, but I can’t find it in the list of sources in ‘Volume settings for each source’.
Hi @ROSEHAN,
Adjusting “opt/coax in” did the trick, but is it possible to split arc, opt and coax so one can adjust each one of them?
The arc, opt and coax you are talking about cannot be adjusted individually.
Thanks. It’s not an issue for me right now adjusting the arc via opt/coax, but maybe you could add a split to your to-do list for a future update
