Hi, I have a problem with the sound on the RS520 when connecting the TV via HDMI Arc. When I use cable TV, everything is fine, but when I switch to the Netflix application built into the smart TV, this happens:
- when switching from cable to Netflix, a strange digital sound appears in the speakers for a moment
- the sound is not synchronized with the video, there is a shift of some fraction of a second
- after returning to cable TV, there is also no synchronization, only after turning off and on both devices, the synchronization on cable is ok
- after turning on Netflix, the volume has to be turned up much, much higher. Additionally, sometimes the sound on Netflix can fade out every few seconds to a second, sometimes 2-3 seconds.
How can I deal with this, what should I do to make it work properly?
TV: Sony KD65xh9096
Rose RS520
