I have connected a ROSE RS130 to an Anthem AVM90 using a 50’ HDMI cable.
I hear small faint ticking in certain tones of music. It is soft/low volume (same volume and same rate of ticking). I compared this to a 35’ Toslink and a 50 Coax cable that produce no ticking. The ticking does not happen when the music/audio is paused or stopped.
Would this be caused by using a 50’ HDMI cable?
I have changed the HDMI output settings (with/out HDMI bypass, bit rate limits, etc.)( with no change in behavior.
Has anyone else ran into this or know how to eliminate the ticking?
