Hi There,
I am considering buying a RS520, but I have one question….
Outside of buying a headphone amplifier, can you connect headphones by cable or Bluetooth to this system?
Joe
Hi There,
Joe
We are sorry for the late reply as we participated in an audio show held in Korea last week.
Rose devices use a Bluetooth profile that receives sound sources. Bluetooth profiles that transmit sound sources are not supported
So, if you want to use Bluetooth Speaker or Headphone, you must connect and use the Bluetooth transceiver.
If that’s the case, any suggestions for Bluetooth transceiver ?
It is difficult for me to recommend a third-party Bluetooth transceiver.
A variety of Bluetooth transceivers exist for each price range.
I recommend that you search the Internet for a Bluetooth transceiver that meets your requirements and then use it.
You should at least tell us the basic technical requirement, so we can source around
