Help on Bypass Lock Setting
Just purchased the RA180 to go with the RS150B. They form a very beautiful and very nice sounding system. Thank you!
In the Rose Amp Connector app, there’s a feature called Bypass Lock Setting.
It comes with the options of LOCK and UNLOCK.
Does LOCK means the bypass function is DISABLED or ENABLED ?
Also when this feature is set to disabled, does it mean that the Bypass lever next to the powe switch on the machine has no function as well ?
A bit confused by the names. Please help explain.
It’s a safety feature. If the Bypass lock on the app is enabled (on) , the bypass lever on fascia doesn’t work. This is to prevent you flicking it on by accident while your preamp or source has its volume up. When the lock is off, you can move the bypass Lever to on. The ra180 then plays as a power amp and will give full power out, blowing your ears or speakers or both if you source isn’t low.
Only unlock this when you are sure your preamp or source has the volume down and the lever is set to off.
Got it, Neil. Bypass lock on, bypass function disabled.
Thanks for the explanation.
Best,
