Hi @ROSEHAN,
I noticed a reproducible display issue on my RS130 when playing music from Qobuz.
When a track is streamed for the first time, the Hi-Res Audio icon is displayed correctly. Once the same track has been stored in the internal cache (green dot on the Qobuz icon), the Hi-Res Audio icon disappears, although the file format remains exactly the same.
Yesterday I updated my RS130 to the latest firmware. I also cleared the cache and even performed a factory reset. Unfortunately, the issue still persists.
This is not a new issue. I have noticed the same behavior for quite some time, including previous firmware versions.
Could you please investigate this issue?
Thank you very much!
@Philsisch
This function is only supported by RS 130.
A green or blue ICON means that the album or track has been cached.
Thank you for your reply.
Unfortunately, your answer does not address my actual question at all.
I did not ask what the green/blue dot means. As I already explained in my original post, I know that it indicates a cached track.
My question is why the Hi-Res Audio icon disappears as soon as the track is played from the internal cache, even though it is still exactly the same 24-bit FLAC file.
The two photos clearly demonstrate the issue. Please review my original post again and provide a specific answer to this question, or forward it to your software team for investigation.
@Philsisch
We have confirmed this issue with our software development team, and they have informed us that they are currently working on a fix.
We will do our best to ensure that the fix is completed as soon as possible and included in the next software update.
Just a quick confirmation: the issue has been resolved with the [Official] Version (OS 5.11.07) update.
Thank you for fixing this!
