Hifi Rise RS130 compared to a OS Audio Airlens
Has anyone out there have tested or listened to both of them I know the 130 offered more but I am questioning the sound quality you know depth staging etc
Hi there Bustin’, I’ve compared both devices, although not in a real good acoustical environnement. For me, the Rose definitively is the better choice, although quite a bit more expensive. Resolution and width and depth of sound stage, as well as overal refinement are better with the RS130. For me, the difference in SQ is worth the price gap.
The RS130 also has some advantages in technical features, but that’s beside your query.
Of course, you can only decide for yourself after comparing. YMMV.
