Hifi Rosé 150
I can highly recommend to try a synergistic Research Master Fuse s 4a 250 v zo much better! It’s a 3D soundstage with way more dynamic contrast, dynamic shading. Holographic
Hifi Rosé 150
Thanks Bob for the fuse recommendation.
May I know what’s the spec and price of it ?
Hi Tom, price is €650 I do not have the specs only my ears sorry !
Thank you Bob. Yes, as long as it pleases our ears.
Tom
Before bedtime i apply Shiseido
Future Solution LX
Total Regenerating Cream
to the inside of my ears. After a nice sleep this gives me much clearer instrumental seperation and smoother highs in the morning
Unfortunately it doesn’t applied to my RS520….which got no fuse to be replaced.
Hi Bob,
Thanks for sharing. I just gotten RS150B.
May I confirm if RS150B is using F3.15A (fast blown) fuse type?
Hi Rose support,
May I confirm if RS150B is using F3.15A (fast blown) fuse type? Appreciate your advice on Rose RS150B fuse rating specs. Thanks!
I think it’s a slow blow
Fuse for RS150B is…
T3.15AL / 250V (Slow)
Hello, please use 5 * 20 mm.
Hi @ROSELOA
May I check why my newly purchased RS150B fuse is shown as JF3.15A (see attached picture)?
So is it using fast or slow blown fuse type? It’s quite confusing as it doesn’t tallies with the fuse on my RS150B
No idea. Mine is the same as ROSELOA provided.
Hello, both are fuses applied to brand new products with the same specifications.
You don’t need to worry.
