I would like to ask for your help regarding my HiFi Rose RA180.
I noticed a crackling noise from the right speaker when I change the volume with the remote control. This only happens when I adjust the volume by remote.
If I turn the volume control by hand on the amplifier itself, there is no crackling noise.
One more detail: after moving the volume up and down several times, the noise disappeared. At the moment, the unit is working again, but I am concerned that this may indicate a problem with the motorized volume control or another internal issue.
Summary of the issue:
• Crackling noise only from the right speaker
• Only when adjusting volume with the remote control
• No noise when turning the volume knob by hand
• After repeated up/down adjustment, the noise disappeared
Could you please let me know:
• whether this is a known issue
• what the possible cause might be
• whether you recommend service or further testing
Thank you in advance for your support.
