HiFi Rose RS130 RoseTube playback issue at 4K resolution
HiFi Rose RS130 RoseTube has stopped playing videos in 4K as of today. There has been no recent firmware update or settings change on my side. My internet connection is 1Gbps, using wireless, and I have no internet issues with other devices or services.
RoseTube videos now appear to play only at a lower resolution, and I cannot force or select 4K playback. Please advise whether there is a known RoseTube service issue, a server-side change, or any setting I should check on the RS130.
Thank you!
We have identified the issue and are currently reviewing it. I will leave an update if there are any progress.
Thank you for the quick response.
I have the same problem here on RS150B. Video plays on 640x480 while settings are on 3840x1880
Same Problems in all Devices (151, 520, 250A)…
When will a bug fix finally be released?
Yes, same Problem here (151, 250A). RoseTube, YouTube is the most used feature in my Setups! I hope for a fast Solution für this Resolution Problem.
The updated version of the rosetube app has been released today. Please check after updating.
Did a short test. It seems to be fixed :+1: Thanks!
