Updated the latest SW for HiFi Rose RS150B after which the audio levels have dropped drastically
Can someone please help me to resolve the issue
Необходимо заново выставить mv в настройках выхода
In English, if necessary.
Update seems to have wiped out the output voltage settings. If using the fixed output, yo need to go to the output settings and select the voltage level you’ve had before.
Thank you very much Denis, issue resolved
Thank you very much BorisM, issue resolved
You’re welcome. Glad it’s working now.
Any other issues with the software upgrade?
Any new features worth the upgrade?
I’m very hesitant after previous upgrades to jump onboard…
There are no major issues with this update.
Aside from the Qobuz Connect disconnection issue, you should be able to use your Rose device without any problems.
