good evening I ordered an rs520 it is on the way! I saw that the height was 12cm I would like to know if we can remove the feet so that it fits in my 10cm piece of furniture
Allag Aziz
It is possible to remove the feet of the RS520, but it is not recommended.
The reason is that you can remove the foot after removing all the boards inside.
If you need to remove the foot, contact the dealer in the country where you purchased it.
We will be happy to help.
