Hifi rose rsa780 with other dacs?
I was wondering if the CD-drive rsa780, only works with Hifi Rose products, or can you use it as a transport with other dacs?
many thanks in advance.
Hi gnarson,
The connection method of RSA780 is the same as that of a general USB CDROM device. It can be used as a CD/DVD ROM when connected to a device that supports USB CDRom.
However, the RSA780 does not have a digital output port(such as Optical or COAX.).
Therefore, the RSA780 cannot be used directly with a DAC.
Best regards,
Kevin
