Is there any chance that the RS 520 can auto turn on once it get’s a signal? Like a Sonos Arc does etc. It feels really sluggish to have to select the input every time.
Any chance of a reply on this from the team?
Roseloa,
This would be a perfect feature addition for the RS 130 and would address my question of a remote turn on/off ability.
This doesn’t seem to work at all with my LG C3 OLED TV. It does put the audio through but it doesn’t seem to turn my device on/off or anything like that. Any more pointers for the the Rose team here?
Any update/support here?
RS520 supports eARC, allowing power interlock when connected to a TV via eARC. Volume is interlocked by default, and if you turn on the corresponding setting, power will also be interlocked.
(RS520 > IN/OUT Settings > Input menu > eARC power interlock)
Great but what about the RS 130?
Rosehan,
Thank you. Would it hurt the fidelity of the signal to have had an EARC HDMI out instead of the existing HDMI or is it a matter of cost?
This is an EARC HDMI in port, not an EARC HDMI out port. This is a different issue than price. The difference is in usability.
Thank you, is the 520 the only model with this feature?
Yes, among the current Hi-Fi Rose devices, RS520 is the only device that supports the eARC function.
Thank you for the clear answer. You make a beautiful product but for those of us with the need for a DAC streamer that sits in our family room, when the family turns on the TV, its gotta be seamless and easy for them… no touching Dads stereo. The Node X does this, so will the NAD M66. If you have something on the horizon, I would take a look at it but until then, I’ll prob get the M66. Thank you
My family hates me for that upgrade to Rose.
They need to manually select HDMI ARC input every time they want to watch the TV
Indeed it’s terrible. Is there not a way the rose can auto switch to HMDI arc if it get’s a signal? Or at least have some remote command or trigger than can go to it instantly.
IMO It should be connected all the time - Volume control with TV Remote should be available even if we are not watching the TV, but e.g. listening the Tidal.
This is what I’m used to have with prev devices - single TV remote for everything. This is what HMDI ARC should be for…
In combination with my Samsung GQ75QN95A TV auto power on/off does work over HDMI eARC. However, sometimes the TV does not automatically switch to HDMI and instead uses its build-in speaker. But I think, this is not an issue of the RS520, is it?
I tested this with both setting HDMI output on my Samsung TV to PCM and to Auto.
Hi again, meanwhile I found out that the RS520 behaves a little bit unusual with regard to the power on/off function of the HDMI eARC input.
If I switch on my TV, the RS520 in standby mode will be automaticalle switched on and if I switch off my TV, the RS520 will automatically switched back again into standby. So far, so good.
However, the switch on process of the RS520 lasts too long, so that my TV does not internally switch to its HDMI output and instead uses its internal speaker. Hence, I have to switch the to the respecitve eARC input of my RS520 via remote control or App.
Another problem is that the RS520 does not switch into standby mode after switching off my TV when the LCD screen is off. Instead, it then just switches on the LCD screen and that‘s it. So, I have to bring the RS520 into standby mode via remote control or App.
Some of these problems might be due to my Samsung TV, but some others should be solved by a respective firmware update.
