Hot Pin in Power Socket in RS 151
I have a question about the hot pin in the power socket on the Rose RS 151.
Looking from the back of the device, is the hot pin on the right or left?
I’d appreciate some verified information, or perhaps someone from the device manufacturer.
@Cougar2025
Looking from the rear of the RS151 (where the power inlet is facing you), the hot (live) pin is on the right side, while the neutral pin is on the left. This follows the standard wiring convention for IEC power inlets.
Please ensure that you are using a properly grounded power cable and a certified power source for optimal safety and performance.
Thank you for the information.
